It is currently Wed Aug 20, 2025 4:07 pm
Post new topic Reply to topic  [ 101 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Thu Sep 26, 2013 1:35 pm
Be sure to do it when you rout the binding channels. Easy to forget. I have "did you shellac the top?" Written on my binding channel rig.
These users thanked the author Terence Kennedy for the post (total 2): Pmaj7 (Thu Nov 07, 2013 5:41 pm) • Steven Bollman (Thu Sep 26, 2013 1:54 pm)
PostPosted: Thu Sep 26, 2013 1:56 pm
First name: Steven
Last Name: Bollman
City: Emeryville
Zip/Postal Code: 94608
Thanks, Terence! I appreciate that tip.
PostPosted: Fri Sep 27, 2013 12:51 am
First name: Steven
Last Name: Bollman
City: Emeryville
The height adjustment on my vise stand is unbeatable.
Finally cut the neck out of the hunk of mahogany.
I'm pretty happy with it so far.
Almost perfectly quarter sawn headstock.
PostPosted: Fri Sep 27, 2013 7:18 am
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
That vice stand is way cool...I want one!
Nice chunk of hog....!
These users thanked the author Robbie_McD for the post: Steven Bollman (Sat Sep 28, 2013 9:23 am)
PostPosted: Sat Sep 28, 2013 9:23 am
First name: Steven
Last Name: Bollman
City: Emeryville
Splitting the billet to make the brace wood.
I think this is pretty good. Pretty straight grain.
Woodworking tools can bite!
This brace is rejected. The grain is too wavy.
PostPosted: Sat Sep 28, 2013 9:25 am
First name: Steven
Last Name: Bollman
City: Emeryville
It always amazes me what people throw out. It works so well with the vise on it.
PostPosted: Sun Sep 29, 2013 2:24 pm
First name: Steven
Last Name: Bollman
City: Emeryville
Things are about to get scary as I prepare to cut out the sound hole. I really needs to be perfect without chipping or tear out.
I got lucky again. Good result! Phew.
PostPosted: Sun Sep 29, 2013 2:29 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
As for chipout protection, I found Stewmac's carbide bit, while expensive cuts very smoothly without any fuzzy edge or chip outs. Now I do not know how long they will last but they work very well, much better than the HSS end mills I used to use.
Typhoon Guitars
These users thanked the author Tai Fu for the post: Steven Bollman (Mon Sep 30, 2013 1:24 pm)
PostPosted: Mon Sep 30, 2013 1:36 pm
First name: Steven
Last Name: Bollman
City: Emeryville
Planing the X-braces.
Working on the X-braces. A laminate of Lutz spruce on the outside and Koa on the inside.
Rip cutting a plank of Spanish Cedar for what will be the kerfed linings.
Trying to be efficient by planing three strips at once. It worked!
Planing the bevel onto the lining.
Almost done. The last step before installing is to kerf the strips. I'll show that in the next post.
PostPosted: Mon Sep 30, 2013 5:39 pm
First name: Claire
Last Name: Arendse
City: Sydney
State: N.S.W.
Oh my, that is looking really nice. I'm looking forward to seeing some more pics and progress reports.
Cheers!
These users thanked the author claire_au for the post: Steven Bollman (Tue Oct 01, 2013 2:18 am)
PostPosted: Tue Oct 01, 2013 2:19 am
First name: Steven
Last Name: Bollman
City: Emeryville
Kerfing the Spanish Cedar linings.
Kerfed linings are done. They will have to wait their turn to be installed.
A diversion... I worked on an ebony pick guard. Shape is not quite there yet. If I decide to use it, it will be the last thing glued to the guitar. I have time to think about it.
PostPosted: Fri Oct 04, 2013 2:26 am
First name: Steven
Last Name: Bollman
City: Emeryville
This is the blank of mahogany I cut a one piece neck out of last week. I am now attempting to make a bird's beak joint between the neck and headstock.
I think it took most of y day to figure out the layout. Believe it or not, there isn't much info on the internet about this joint. A little bit, not much. No dimensions. I've written them on the wood in case it comes out right I'll have something to go with should I choose to build another guitar with this style neck.
Side dimensions.
Getting the chance to use my magnificent Independence Dovetail saw. I think Lie Nielsen bought them out 13 or so years ago.
Close up for tool dorks.
Sawing and paring...
Let the chiseling begin. Using an old Stanley #50 Everlasting chisel.
Paring with a Robert Sorby paring chisel.
Rough fit. Tomorrow I'll do the final fit.
The headstock and neck still have to be shaped.
PostPosted: Sat Oct 05, 2013 1:46 am
First name: Steven
Last Name: Bollman
City: Emeryville
Here's the neck and headstock assembly held together with gravity. The head plate is Madagascar Rosewood.
PostPosted: Sun Oct 06, 2013 7:59 pm
First name: Steven
Last Name: Bollman
City: Emeryville
This is why this particular headstock/neck joint is call a Bird's Beak joint.
Getting ready to shape the neck.
I'm using a paring chisel...
...and also a rasp that I bought about 15 years ago from a nautical supply store on the embarcadero in SF. I don't think it's still there. The upstairs storage room was loaded with new old stock of all kinds of tools. I bought a bunch of files and chisels for peanuts.
It's a slow process. Lots of touching and feeling.
Little by little... I still have a lot of material to remove.
Last edited by Steven Bollman on Sun Oct 06, 2013 9:16 pm, edited 1 time in total.
PostPosted: Sun Oct 06, 2013 8:39 pm
First name: Rob
City: Cochrane
State: Alberta
Great progress!
You originally cut a 1-piece neck - why the switch to the birds-beak?
What was the the inspiration for the laminated x-braces? How wide will they end up?
These users thanked the author Robbie_McD for the post: Steven Bollman (Sun Oct 06, 2013 9:08 pm)
PostPosted: Sun Oct 06, 2013 9:01 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
So what advantage does a bird's beak neck joint offer? It seems to be far more complicated than a scarf joint.
Typhoon Guitars
These users thanked the author Tai Fu for the post: Steven Bollman (Sun Oct 06, 2013 9:13 pm)
PostPosted: Sun Oct 06, 2013 9:12 pm
First name: Steven
Last Name: Bollman
City: Emeryville
Robbie_McD wrote:
Great progress!
Thanks, Robbie. I'm well aware that screw ups are lurking everywhere. I bought a piece of mahogany that makes two necks, so I thought I'd make two. I really like the birds beak joint with the real volute. I thought I'd try it and see which neck looked best. The Stahl design (Larson Bros.) calls for a laminated X-brace. It will be significantly smaller when I get done with it. The design calls for 9/16" x 5/16".
PostPosted: Sun Oct 06, 2013 9:15 pm
First name: Steven
Last Name: Bollman
City: Emeryville
Hi Tai Fu. It's more complicated. I can't say I know for sure if it's stronger. More than anything, I liked the idea of attempting it. It's an elegant joint. If it comes out nicely than I'll be happy.
PostPosted: Mon Oct 07, 2013 12:11 am
First name: Steven
Last Name: Bollman
City: Emeryville
Some more refining. I think I still have to remove a lot of material.
PostPosted: Wed Oct 09, 2013 12:00 am
First name: Steven
Last Name: Bollman
City: Emeryville
What do folks think... The "B" is a tad higher than I intended. Generally I'm pleased for a first inlay. I'm I being too anal?
PostPosted: Fri Oct 11, 2013 12:11 am
First name: Steven
Last Name: Bollman
City: Emeryville
Headstock slots drilled and cut lines laid out. This is my second headstock. I screwed the first one by trying to freehand drill a 1/2" diameter bit and expected it to come out on the other side where I wanted it to. Fat chance. It wandered. The good news is this head stock fits really well and is much tighter.
Headstock slots roughed in. More refining tomorrow.
Side view of headstock and volute.
Another angle of the back of the headstock and volute.
PostPosted: Sat Oct 12, 2013 1:44 pm
First name: Steven
Last Name: Bollman
City: Emeryville
Sanding the headstock slots.
Laying out the fret slots.
PostPosted: Tue Oct 15, 2013 1:25 am
First name: Steven
Last Name: Bollman
City: Emeryville
Getting ready to assemble the bird's beak joint.
Here its goes.
Using a nylon strap and clasp to clamp the headstock and neck during the glue up. I'm using Hot Hide Glue for all you glue aficionados.
Trimming the base of the head plate where it meets the nut.
Gluing the head plate to the headstock. Using an old headstock as a clamping caul.
Tapering the ebony fret board.
Getting ready to make the "ramps."
Using a 1/2" round rasp.
The finished ramps.
PostPosted: Tue Oct 15, 2013 3:39 am
Last Name: Paulin
State: Qld
Lovely work Steve,
You know your way around hand tools.
Regards from RangeView, Bill
These users thanked the author P Bill for the post: Steven Bollman (Tue Oct 15, 2013 11:52 am)
PostPosted: Tue Oct 15, 2013 11:53 am
First name: Steven
Last Name: Bollman
City: Emeryville
P Bill wrote:
Lovely work Steve,
Thank you P Bill!!!
Users browsing this forum: Bing [Bot] and 16 guests
